Trouble starting car a week after getting timing belt replaced at shop.
Old Sep 29, 2017 | 09:18 AM
adayandforever's Avatar
Default Trouble starting car a week after getting timing belt replaced at shop.
I took my 2002 Honda Civic to a shop to get some seals replaced because of an oil leak, I also got my timing belt replaced while it was there. The car seemed to be doing fine, the leak problem was solved, but I did notice that it seemed a little louder when shifting into higher RPMs, also maybe a little shakier in idle. Though the leak was a problem, I never had any problems starting the car. A week later after I got the car back, I began having problems starting the car. It would sometimes take me multiple times to start the car. Wasn't a battery issue, I checked the battery, everything seemed to be pointing to the starter. Now after having problems for a week, it just won't start at all. Could this have anything to with the timing belt replacement? I took it back to the same shop and I'm waiting to hear back from them. Any help would be appreciated, thank you!
Old Oct 27, 2017 | 05:05 PM
Duane4238's Avatar
Have them check the crankshaft position sensor and its plug. They may have unplugged it when they did the timing belt or possibly "disturbed" it. This just happened to my 05 when they did the timing belt. It then shorted out the crank sensor and melted the plug. Dealer wanted over $500 for a new wiring harness. Just the plug is not available from the dealer, NAPA, Autozone, etc. I finally found just the new plug with pigtail on Ebay for $19.00. Seems to be somewhat of a common thing with the Civics. Good luck.
Duane
jrcastro
Apr 21, 2011 04:27 AM
Jack Shephard
Feb 14, 2009 06:53 AM
dave_57204
Feb 5, 2008 08:14 AM
dave_57204
Jan 27, 2008 10:16 AM
stressballs
Aug 18, 2007 06:34 AM
