Front Passenger CV Joint leaks grease
Old May 27, 2012 | 05:15 PM
tooquick's Avatar
Default Front Passenger CV Joint leaks grease
I purchased a used 96 civic ex with 106,000 miles last week. I noticed the front left cv joint leaks. Any recommendations on what I should do. Do I have to replace the whole joint?
Old May 27, 2012 | 06:18 PM
Spin the wheel in neutral while the car is up in the air and check for tears. If torn, you can try to replace just the boot, but it is easier to just swap the axle IMO since the one that would need to be re-done would have to come out anyways.
If there is no visible tear, I would clean up the fluid and continue to watch it. I have seen some axles packed with too much grease and the excess starts slinging out when moving.
Does the car click or make any sort of drive train noise when turning or accelerating from a stop?
Old May 27, 2012 | 06:25 PM
tooquick's Avatar
No it doesn't make any clicking noise, none that I have noticed anyway. I didn't see any tears either. I will clean it completely and continue to watch it
Old May 27, 2012 | 07:12 PM
bigmeat's Avatar
If its not making noise when turning just watch it.
cwarnick
Sep 13, 2010 07:55 PM
evictor99
Dec 5, 2009 01:00 PM
ordep71
Aug 21, 2008 09:55 PM
Amateur
Jul 23, 2008 06:54 PM
GirlwithanSIattitude
Dec 2, 2007 11:27 AM
