Fuel economy issues still
Old May 4, 2010 | 05:00 PM
darren509's Avatar
Default Fuel economy issues still
98 Civic LX 164000 miles. Recently has new timing belt and water pump, distributor E3plugs NGK wires new aftermarket CAT and new tires as well. It used to get 300 miles per tank now only 200. timing was previously about 2* retard, tried at 2* advanve with no change. NO ckeck enging lights or codes. PCV works properly.. Any ideas what would cause this much of a drop without throwing any codes???
Old May 4, 2010 | 06:04 PM
runrider's Avatar
burnt out check engine light bulb? Does it come on when you first put the key in?
Old May 4, 2010 | 06:30 PM
darren509's Avatar
It works fine..
Old May 4, 2010 | 07:39 PM
civichb98's Avatar
I got the same problem and I have 130,000 miles but it's been like that for a while.
Old May 6, 2010 | 10:53 AM
badar_VTi's Avatar
i have same problem.. i have a EK with 105,000 miles on it had it serviced and everything but still even on the motorway doing 70mph only gives me round about 200miles and in town its just bonkers 20 pound only gives me about 80 or less miles thats if its over half tank man i dont no WDF is going wrong iv put it down to engine being old and with many miles correct me if im wrong
Old May 6, 2010 | 11:01 AM
^^^That's a bold statement.
To get some ideas on what to check, have a look at this thread:
https://www.hondacivicforum.com/foru...ad.php?t=82689
Also make sure you are adjusting the ignition timing with the service connector jumped and aligning the pointer with the red mark on the crank pulley.
Old May 7, 2010 | 03:58 PM
darren509's Avatar
Thanks Ron, (once again) I had my timing too retarded, just like the operator I set it correctly and now its about right. Drove 40 miles allready and gas gauge has bairly moved. Looks good for now. Thanks for helping me un-stupify....
davejurek
14
Apr 27, 2008 06:10 PM
cot266
Jun 7, 2006 03:11 PM
D16z6
Apr 6, 2005 02:56 PM
spevie
Oct 6, 2004 06:53 AM
