fuel problem with 93 eg coupe
Old Jun 7, 2010 | 06:37 PM
2low93's Avatar
Default fuel problem with 93 eg coupe
i have recently put a obd2 d16y7 in my 93 ex couple...it crank up when i put the motor in the car then i broke a axle and had to drop the tranny to fix it. Well i try to start it again after i put the tranny back in the car and it wouldnt...i didnt hear the fuel pump cut on so i took the pump out and testded it and it was good so then i went to the main relay and that was good so i test the two wires goin to the fuel pump and the hot wire im not gettin and current...but the whole wire from the relay connector to the pump does have any current so what is there to do to get it workin again...plz help me out i have ran out of thing to do on the car!!!!!!
Old Jun 8, 2010 | 03:49 AM
Check the ground wires, big one on the transmission and small ones on the thermostat, and anything else that may have been disturbed when R&R transmission. Losing the ground will prevent the ECU from powering up. If that's the case you won't have spark either.
CivicEX2006
Sep 20, 2007 03:32 PM
4doorcivic9
Jul 11, 2007 10:54 PM
seriously_furious
Aug 14, 2006 08:49 PM
TheBlackCivic
Jul 16, 2006 11:45 AM
nightrider46
Aug 23, 2005 03:42 PM
