Fuel Pump
Old Oct 17, 2005 | 08:56 PM
ngoti 8tor's Avatar
Default Fuel Pump
I want to do some wiring, so before I go ripping stuff apart, I wanna make sure of something. The fuel pump is in the gas tank, beneath the rear seat, is this correct? Does anyone know which color of wires are for the fuel pump?
Edit: BTW, on a 7th gen LX.
Old Oct 17, 2005 | 09:03 PM
Pete's Avatar
Default RE: Fuel Pump
im pretty sure its under the rear seat. Check the owners manual for the wire colors, it might have it. A haynes manual will DEFINETLY have it.
Old Oct 17, 2005 | 10:01 PM
ngoti 8tor's Avatar
I haven't had a chance to buy a service manual yet, so I was hoping someone could tell me that already has a service manual.
(I've been looking on eBay, and all I've seen was Haynes, but I heard Chilton was better.)
Old Oct 18, 2005 | 01:40 AM
ngoti 8tor's Avatar
Can anyone else confirm that the fuel pump is under the back seat in the tank?
Old Oct 18, 2005 | 02:46 AM
Super Mario's Avatar
I think that they all are if you think about it. They spare is in the trunk, and the passenger foot boards can't hold a gas tank, so that leaves under the passenger seat-last part unchecked in the rear. If you can jack your car up you can see the gas tank straps. that should give you a better idea of where it is located. I would put my money on that area there under the seat.
Old Oct 18, 2005 | 11:07 AM
ngoti 8tor's Avatar
Thanks, guys! I thought it was, just wanted some confirmation.
Old Oct 18, 2005 | 11:47 AM
Chimera02EX's Avatar
Yo ngoti8tor your fuel pump in under your rear seat. If you lift that puppy up you'll see some wires going into a metal plate in the middle, unscrew that and your fuel pump in right there.
Old Oct 18, 2005 | 12:42 PM
Kappa22's Avatar
In the long run it's usually easier to just drop the gas tank...
Old Oct 18, 2005 | 03:52 PM
ngoti 8tor's Avatar
Thanks guys......that's all I wanted to know.
I don't wanna take out the fuel pump or anything, I just need the wires going to it.
flcb7
Nov 3, 2010 05:21 PM
wkhan69
Aug 9, 2009 10:08 AM
seriously_furious
Aug 14, 2006 08:49 PM
rbsterli
Feb 28, 2005 07:17 PM
JrscCivic00
Jul 1, 2004 02:32 PM
