cant get my 88 hatch to start.
Old Oct 9, 2005 | 02:46 PM
dj_ipirate's Avatar
Default cant get my 88 hatch to start.
here is the problem. it will crank like it wants to start. (when you turn the key) but the engine will not activate. im thinking it might be the distributor, but im not compleatly sertain. help me out guys
Old Oct 9, 2005 | 06:12 PM
Mad7s's Avatar
Default RE: cant get my 88 hatch to start.
Hmmmmmmmmmm. Some simple things to check out and start with would be to see if the battery connections are tight, give the battery a charge or try a jump, and check the spark plug gap. Best of luck.
Old Oct 9, 2005 | 06:57 PM
AgentofDarkness's Avatar
Start with the basics, your car needs fuel, spark, air and compression to run. Check the spark first, pull the plug wires out and attach a spark plug to it, check if there is a spark. To check if there is a problem with the fuel, spray fuel through one of the vacuum ports in the top of the cylinder head. You can also run a compression test to see if teh compression is correct. Hope it works out for you.
Old Oct 18, 2005 | 09:12 PM
89civichatch's Avatar
main relay 40 bucks from honda
Old Oct 18, 2005 | 09:41 PM
ohbiskits's Avatar
ORIGINAL: 89civichatch
ha..almost always the problem on old school civics.....definatly check spark and fuel...and let us know...if your not getting either of them its prolly hte main relay
Old Oct 18, 2005 | 10:31 PM
riceburner700's Avatar
how dirty is your engine bay and how many miles on there car
ahloy128
Mar 10, 2012 11:27 AM
whitworthsean
Nov 8, 2007 09:22 PM
civicexracer
Mar 25, 2006 10:07 PM
wrighthonda
Feb 28, 2006 04:49 PM
Boost231
Feb 11, 2006 07:14 PM
