1992 honda civic with a LSV Turbo Swap. cant get it to start
Old Feb 22, 2012 | 12:40 PM
ahloy128's Avatar
Question 1992 honda civic with a LSV Turbo Swap. cant get it to start
hi i have a 1992 honda civic hatchback wit a LSV turbo. when i first got the car it was running good but now i cant even get it to start. i have been working on it for over a year now and still cant figure the car out so i need some good advice. since the car havent start ive change the coil, plugs, wires, main relay, tps sensor, map sensor, fuel filter, distributor cap, and the car still dont want to start. it has a obd1 ecu with hondata chipped. the only way we got it to start was when me and one of my buddy worked on it and how we got it to start was me crankin on the car while he put his hand over the throttle body and blocked it from getting air from the intake pipe and it started back up. took it for a test drive after and it runs good but when i floor it the car would bog down on me and its like its not getting a good spark or enough fuel. so if theres anyone out there with any good advice plz help me out cause i'm running out of ideas. thank you and waitin to hear some good advice. oh yeah i made a call to a local mechanic and he said it could be my fuel filter or fuel pump. it cant be the fuel filter cause i just replace it. plz help me out.
Old Mar 10, 2012 | 11:27 AM
Rainman21's Avatar
Sounds like you have some DIRTY fuel injectors so try cleaning those and also look for a vacuum leak because that would prevent the motor from starting/running right.....thats what it sounds like to me hope this helps you
Animal_00
Oct 11, 2012 02:01 PM
ahloy128
Feb 22, 2012 11:46 AM
turbo00EK
Jan 21, 2009 07:00 AM
ryank327
Aug 12, 2007 06:36 PM
dj_ipirate
Oct 18, 2005 10:31 PM
