Gas gauge
Old Jun 1, 2008 | 11:18 AM
camarogirl2683's Avatar
Default Gas gauge
just wondering if any one else has had a problem with their gas gauge not working. I have a 2002 Honda Civic EX. I have had numerous problems with my car from the start. Today I filled up my tank and the needle stays just a little belowhalf a tank. I am really hoping that it isn't broken but with my luck it probably is.
Old Jun 1, 2008 | 11:58 AM
Default RE: Gas gauge
Perform these diagnostic tests:
Old Jun 1, 2008 | 04:50 PM
regor's Avatar
If it is broken and the dealer wanst to charge a arm and a leg, just buy a scanguage that hooks into your OB2 port. You can enter data about your gas tank size and that will tell you how much is left, how far you can go and how you you can go till you're on empty. ALso, it's a great guage for helping in improving your MPG
Old Jun 1, 2008 | 05:16 PM
ej6buddy's Avatar
usually it's either the sending unit in the tank itself, or it's the magnetic unit in the gauge cluster itself, sometimes they burn out.
Old Jun 1, 2008 | 08:27 PM
well i drove around for a bit and it unstuck from half a tank to a full tank. my fiancee over filled the tank and I am wondering if maybe that caused the gauge inside to get stuck. i figure if it doesn't go down to half a tank after two days of going back and forth to work then something is wrong. not sure if over filling would cause this problem but its worth a shot in the dark....
Faramire
Sep 7, 2009 02:27 PM
siwel177
12
Jul 17, 2009 06:47 AM
TurboToyzz
Feb 16, 2007 12:46 AM
millertime17
Jun 26, 2005 09:38 PM
packman5280
May 18, 2005 07:51 PM
