Hatchback with damp trunk
Old Mar 28, 2007 | 09:41 AM
ChevyTruck's Avatar
Default Hatchback with damp trunk
My 93 Civic hatchback has a damp trunk. The hatch seal appears to be in good condition. I have heard the the tail light gaskets can fail over time. How do I remove the tail light and rear marker light housings to check/replace the gaskets? Any thoughts on how to troubleshoot?
Old May 15, 2009 | 07:57 AM
Castanea_d.'s Avatar
I'm another person with a damp trunk - 96 Civic hatchback. In my case, the hatch seal might need replacement, but it doesn't look THAT bad, not enough for the amount of leakage I'm getting. Any suggestions or tips?
And does anyone have thoughts about ChevyTruck's question about the tail light gaskets. Could that be the cause of my problem as well?
Old May 15, 2009 | 10:36 AM
zsatbecker's Avatar
hahahaha i had a damp trunk in my 97 hatch and couldnt figure out where the water was coming from at all. so i finally gave in and started to investigate farther and found that at the very top of the hatch the trim was split and seperated and water was getting in through a space about an eighth of an inch at an alarming rate. so i picked up a brand new hatch gasket from the honda house, replaced it, then put a dehumidifier in the trunk over night and it was dry the next day and stayed that way.
Old May 15, 2009 | 11:05 AM
Where is it getting damp at, specifically?
The seals should be soft, and not stiff. Try lubricating them with silicon grease (even if they're not stiff, they could probably use it).
peteyb
Mar 5, 2012 12:40 PM
reich17
14
May 20, 2011 12:34 PM
joer1989
Sep 23, 2007 09:26 AM
addiction2bass
Jun 8, 2007 06:02 PM
Nitrojin
Jul 17, 2004 03:08 PM
