Head stuck to Block! HELP!!
I have a 1990 Honda Civic Wagon (1.5L)
Well, I have a blown head gasket (almost certain, if not, it is a cracked head or block
) Well to get this taken care of, I got my exhaust manifold off and my intake manifold off (I have completely removed them from the head; I actually even removed the gaskets.) I also remover the timing belt from the pulley, and the water hose pipe and other sensors from the side. Now I removed all 10 of the head bolts, however the head doesn't want to move a bit.
I have already tried using PB Blaster, lever the head off using a breaker bar (It seems to lift the whole block up with it as well),tried to pry it using my screwdriver (the screwdriver was a little too big), tried whacking it with a rubber mallet (my mallet was chopped) however I have not had any results as much as simply moving it a bit.
Is there any other way to do this. Any help would be really appreciated.
) Well to get this taken care of, I got my exhaust manifold off and my intake manifold off (I have completely removed them from the head; I actually even removed the gaskets.) I also remover the timing belt from the pulley, and the water hose pipe and other sensors from the side. Now I removed all 10 of the head bolts, however the head doesn't want to move a bit.I have already tried using PB Blaster, lever the head off using a breaker bar (It seems to lift the whole block up with it as well),tried to pry it using my screwdriver (the screwdriver was a little too big), tried whacking it with a rubber mallet (my mallet was chopped) however I have not had any results as much as simply moving it a bit.
Well, I finally got it off.
I took off the camshaft and the cam gear. No since I had a lot more room to play with, I pulled on the back of the head and leaned back (towards the front of the car). This I think loosened it, and I had to wiggle it around quite a bit, before the whole thing finally came apart.
Well, I'm glad that it finally came off.
Aaron A Archer
Nov 29, 2011 08:37 PM
tombakers
May 4, 2008 05:23 AM
Lost
May 2, 2007 10:52 AM
jo7man4
Jan 27, 2007 01:13 PM
