headlight/speedometer problem
Old Dec 22, 2005 | 04:06 PM
slmdnk9's Avatar
Default headlight/speedometer problem
for reference just installed a new transmission in my 95 ex civic. tranny is from 99 ex.
okay when the headlights are off everything is great. when you turn the headlights on everything is great. but left headlight randomly turns off by itself and when that left headlight turns off the speedometer will stop working. then as soon as the headlight comes back on, speedometer comes back on. well???????
example: wifes driving with the headlights on, so lights are on and left and right light are working and speedo are working, then she hits a bump and the left light and speedo turn off. so shes driving and if she turns off the lights the speedo works if she turns them back on and only the right light is working then the speedo isnt working. then she hits another bump, bam left light turns back on and speedo turns back on.
speed sensor?!?! wiring?!?! possessed?!?!
Old Dec 22, 2005 | 08:13 PM
AOL.COM's Avatar
Default RE: headlight/speedometer problem
i say check check your ground wires first
in your engine compartment
Old Dec 23, 2005 | 01:04 PM
slmdnk9's Avatar
that was the first thing i checked, anyone else?
Old Dec 23, 2005 | 03:16 PM
MR2nCivic's Avatar
well if this started happening right after you installed the new transmission i would say trace the wires from the left headlight back and see if there might be any spots where the wires could be shorting each other out might have pinched a wire when installing the tranny or might be some loose conections thats where i would start
noops
Oct 19, 2007 02:08 PM
stephenmba
Jun 6, 2007 01:01 PM
skateboard
Mar 1, 2007 08:00 PM
mbutz13
Oct 24, 2006 06:36 PM
stang233
Jun 6, 2006 05:08 PM
