Heater problem
Old Jan 13, 2011 | 03:31 PM
KingDakota12's Avatar
Default Heater problem
Well over the summer my thermostat went wacko and found out I needed to replace the thermostat and problem fixed, but now my heat is not very hot. Like the car and thermostat warm up to normal but the air coming from the vents only get about 80% warm and should be much hotter. Problems?
Old Jan 13, 2011 | 03:44 PM
SupaviIIin's Avatar
maybe that flap thing the wire pulls from the heater core didn't open all the way?? (in engine bay near fire wall) or your thermostat has to break in still... (stiff new spring) just a thought.
Old Jan 13, 2011 | 04:15 PM
Did the heater issues come about as soon as the new Tstat was installed? What temp tstat was put in? Was it OEM Honda?
The only other thing I can think of is the heater core being blocked, or the valve not opening all the way.
Old Jan 13, 2011 | 06:21 PM
Yes my heat last winter blew nice and hot, but the second I put in the new thermostat it went bad, and not sure I know it was from Autozone so not OEM and not sure of the temp!
Old Jan 14, 2011 | 05:56 AM
Replace it with one from the dealership would be my suggestion.
Many Tstats from places like Autozone can fail immediately. Either that, or you went with a Tstat which is too low of a temp.
Old Jan 14, 2011 | 06:27 AM
Alright thanks man, so if I go to an OEM site and order one, what temperature should I look for?
Old Jan 14, 2011 | 07:26 AM
There shouldnt be choices. The Honda Tstat is a Honda Tstat. I believe the temp is 180. That is what shows on Hondata when I am tuning etc.
Old Jan 14, 2011 | 07:55 AM
Alright great thanks I will surely get one because I can't stand being cold anymore!
Old Jan 15, 2011 | 12:01 AM
While you have the system drained to replace the thermostat, disconnect the heater hoses from the engine and use a garden hose to flush the heater core just to be sure it is clear. Dial must be on hot to open the valve, then flow it both ways.
Old Jan 15, 2011 | 06:40 AM
^^ That is a great idea while you have everything apart.
tgs
Mar 28, 2010 07:12 PM
civicpimpinsc
Nov 13, 2007 02:36 AM
djburn
Dec 21, 2006 09:20 AM
romic00
Dec 3, 2006 08:06 PM
rpinoh1
Mar 20, 2006 09:40 PM
