Help!!!!1994 honda civic cx
I have a 1994 civic cx hatchback. It has the 1.5 engine, with 120,000 miles. Over the summer the car would not start on hot days. I finally changed the fuel pump as recomended by a few mechanics. Now, my car dies while in neutral and hesitates while driving, but only when I have 1/4 tank of gas (starts right back up). No check engine light, and no problem when I have 1/4 or more tank of gas. After changing fuel pump I changed the fuel filter. anyideas. I have had some people tell me to replace the icv???
Thanks for the help in advance.
andy
andy
You may want to check the pressure regulator (see picture).
[IMG]local://upfiles/25538/5886EB1AAD554517BBBDDBE732D5B003.jpg[/IMG]
Pictures in the next post provide additional information.
More pictures...
[IMG]local://upfiles/25538/ED9E6C75C40044099674F4745F28E91F.jpg[/IMG]
[IMG]local://upfiles/25538/C7A8CCDD1FCE4F97B2D11D35C6A062E9.jpg[/IMG]
ORIGINAL: acj734
ok I will check that, but would that be effected by the level of gas?
Second, yes, a higher gas level in the tank might compensate for borderline weak pressure provided by a faulty pressure regulator.
Ok had mechanic check the regulator . He said it was ok. He thinks the problem is the cam shaft sensor???? Claims he can ge the part for $80.00( inside distributor I guess). Put gas in the car yesterday and now it runs fine (till I get to 1/4 tank).
For what it's worth, faulty TDC/CRANK/CYL sensors in the distributor seem usually to be associated with the CEL being ON, and faults of these sensors cause misfiring or rough running (see picture). I wouldn't want to second guess a good mechanic, but does this fit well with the problems your car is experiencing?
[IMG]local://upfiles/25538/B1FEE4B4AD1842348DA33FCDBD0BFDFD.jpg[/IMG]
Infinite Shadows
Mar 31, 2012 04:14 AM
Brute
Oct 30, 2009 02:09 PM
eovalles
Oct 5, 2004 04:01 PM
kobejelbryant8
Jun 28, 2004 11:11 AM
