HELP me on a leakdown test
[&o] I've done a compression test & found the #2 cylinder way low. added a little oil and the compression came up nicely. Now I am doing a leakdown test with my home made tester appling 90psi into the #2 cylinder and no leakage - should I take the car out for a drive and get the oil hot?
Here is the buggling thing: My set up is a needdle valve - gauge - and a hose (off of a compression tester) connected to the spark plug port. I have 90psi going to the TDC of the cylinder, ok. I close the needle valve leaving the 90psi from the valve to the TDC pressured, no leakage. Now here is the confusing thing - when I turn the crankshaft several time my cylinder remains pressurized - it will not exhaust, it will not even losse a pressure when that particular piston is traveling down. You think with the extra displacement I gained I should have lost some pressure.
I probably could have said all of this more breifly. CAn somebody help me? Thanks
I sent you a PM, but in short a compression tester hose has a 1-way valve that will not allow the air to go into the chamber. The pressure is being held by this valve and never entering the chamber.
addiction2bass
Sep 29, 2007 04:18 PM
keithscianna1
Aug 22, 2006 11:31 PM
1992civicvx
Feb 11, 2005 06:27 PM
