Help me plz!!!
Old Mar 15, 2006 | 08:33 PM
Cutt's Avatar
Default Help me plz!!!
My speedo is going crazy... What could be cause this.
Old Mar 15, 2006 | 08:37 PM
StifflersMom's Avatar
Cat Fuсker
Default RE: Help me plz!!!
Bad ground....clean your grounds and clean your battery terminals...
Fiirkan's Avatar
VSS(variable speed sensor), the connection to the VSS, the gauge cluster itself, i think that there may be some other possible causes but i can't remember... i have the same thing happen to me all the time... i jsut ignore it after a while.. then it works again... the only annoying thing is when your cruising and you see a cop, but you dont know how fast your going.
Old Mar 15, 2006 | 08:48 PM
Cutt's Avatar
Yeah it's really getting on my nerves. I past a cop tonight and I had no clue how fast I was going.
Old Mar 15, 2006 | 08:57 PM
Cat Fuсker
try you battery connections first...it's easier than throwing parts at it and I had it happen on multiple vehicles and that fixed it most of the times
Old Mar 15, 2006 | 09:19 PM
mxs's Avatar
mxs
*moved*
Old Mar 16, 2006 | 07:58 AM
jake11375's Avatar
There was a thread about this the other day. I have the same problem. Speedometer and odometer have worked intermittantly going on 3 months now. I called the dealership and they said it could either be bad cables or the sensor could be going out. I pulled my cluster out last night and kind of played with the cables while driving slowly to see if I could trigger the problem. I know my battery cables are on tight because my alarm remote battery died and I had to pull the battery cables and tighten them back. Dealer wants $80 to check it out. I am getting sick of reading my RPMs for speed and I never know what kind of gas mileage I'm getting. I wish I had another guage cluster to test out....
that_guy5
Feb 9, 2007 08:09 AM
omgxitsxaxhb
Feb 11, 2005 03:08 PM
helpmeplz
Dec 15, 2004 03:43 PM
quincearj
Sep 5, 2004 09:49 AM
imlookin4a50
Jun 16, 2004 01:03 AM
