help running rich
Old Nov 5, 2008 | 09:28 AM
  #21
Originally Posted by LtShackelford
my connector has 3 wires going into it how do i know which to jumper?
Look for the 2P connector.
Old Nov 5, 2008 | 09:38 AM
  #22
The 3 wire connector is used only with special equipment at the factory or dealer. There should be a 2 wire connector right next to it.
Old Nov 5, 2008 | 11:00 AM
  #23
LtShackelford's Avatar
ok i shall look
Old Nov 6, 2008 | 06:38 AM
  #24
it flashed 6 times quickly
Old Nov 6, 2008 | 08:07 AM
  #25
Replacing the 2-wire coolant temperature sensor located under the distributor should solve the running rich problem. The sensor is located adjacent to the one-wire temperature sending unit.
Old Nov 7, 2008 | 05:41 AM
  #26
ok under the distributor
Old Nov 7, 2008 | 01:32 PM
  #27
ok i replaced that turns out it wasnt connected and the clip it was supposed to connect to was broken off the old one. now im still throwing the code for the coolant temp sensor. with the new one in to i unplugged the battery for the weekend and monday ill see if its still there
Old Nov 7, 2008 | 01:38 PM
  #28
but next problem here is the e test
hc ppm limit 82 reading 254
co .45 reading 3.33
no limit 636 reading 1584
at 2022rpm
at idle
hc ppm limit 200 reading 366
co 1.0 reading 4.97
i got a diagnostic for it
it says replace cat
acetylene gas
exh gasket
exh gasket
and replace o2 sensor
my question is wtf is acetylene gas
and how do i find out which gaskets need to be replaced in the exhaust
Old Nov 7, 2008 | 01:54 PM
  #29
Do do you now have a new coolant temperature sensor hooked up? Is the sensor connector damaged?
To clear the ECU of old CEL codes, simply remove the 7.5A BACKUP fuse under the hood for 1-2 minutes and then reinsert. (There's no extra benefit to disconnecting the battery for an entire weekend.) Next run the engine to see whether the CEL stays ON. If so, pull the code again to see whether it is the same one.
Old Nov 7, 2008 | 02:00 PM
  #30
co .45 reading 3.33
at 2022rpm
at idle
co 1.0 reading 4.97
it says replace cat
acetylene gas
exh gasket
exh gasket
First get the CEL code fixed, and then have the emissions test repeated. It's possible that the rich running condition destroyed the cat. Nonetheless, wait for results of a new emissions test before taking any further action.
