Help with shaking front end
Old Jan 18, 2007 | 03:13 PM
bcirk7's Avatar
Default Help with shaking front end
I have a shaking front end on my 94 civic coupe. I originally thought it was my tires because I had popped one a 4 or 5 months ago and stuck on a new one. So I had the difference between tread checked out and it is very very miniscule, so then I moved onto my next possibility, the allignment. The alignment checked out and things grew a little bit better, but everytime I hit past 65, my front end shakes.
I was wondering if anyone had an idea what would be up? My tires are all performance and the same size.
Would a front strut bar help? Any suggestions would be appreciated.
Old Jan 18, 2007 | 06:36 PM
mill$civic's Avatar
Default RE: Help with shaking front end
Did you try getting both wheels balanced? It could be off.
You dont need a strut bar for this problem.
Old Jan 18, 2007 | 11:40 PM
Impreza WRX's Avatar
Things to check:
Wheel alignment - DONE
Wheel Balance - do this during tire rotation
Brake Rotors - you would notice by pulsing brake pedal while braking
CV Axles - Bad vibration above 75 MPH, clicking or knocking while turning, sudden death
Transmission "Torque Stoppers" - easy, look through the hole in the frontward part of the wheel arch, if the rubber is cracked or broken, that is your problem.
If your problem is old rubber cracking/breaking, there are a LOT of important things on the Civic that are rubber and they will ALL have to be replaced eventually!
Old Jan 21, 2007 | 01:11 AM
bcirk7's Avatar
Thank you for the advice, I'll be sure to check it all out.
&Oh man, this old car has been needing a lot of care, if its not the rubber then its the transmission or the brakes or the radiator. loorrdd
Old Jan 25, 2007 | 02:22 AM
transmission - rubber torque stoppers and engine mount bushings, rubber CV axle boots
brakes - rubber seals, rubber hoses
radiator - rubber hoses!
suspension - rubber bushings
electrical - rubber insulation
engine - rubber vaccum lines, rubber spark plug o-rings, rubber distributor gasket
fuel - rubber hoses
Those are the things to look out for. In my car I have a big problem with deteriorated rubber causing problems. I have eliminated a lot on the list, but a lot remains.
smoke42o
Apr 13, 2008 11:37 PM
Spark
May 20, 2007 10:10 PM
leomao
Feb 22, 2007 01:53 AM
bain0005
Jul 8, 2005 02:23 AM
omgxitsxaxhb
Feb 12, 2005 02:04 AM
