hi rev problem
Old May 19, 2009 | 08:39 AM
93txhonda's Avatar
Unhappy hi rev problem
so i was drivin my civic home from work and stopped off at the gas station and noticed that the front passinger tire was low 10lbs so i put some air in also checked all fulids brake was a little low but i got a bottle at the house so i jumped back on the on ramp when i switch from 3rd to 4th at about 4800 it just jumped to 8000 and stuck i put it in neutral at it was just redlining like the throttle was stuck so i pulled off checked the throttle it was workin just fine does any body have any clues
Old May 19, 2009 | 08:51 AM
Is the throttle pedal stuck on the floor carpet? Otherwise, try cleaning the throttle body.
Old May 19, 2009 | 08:57 AM
93txhonda's Avatar
it did stick but when i put it in 5th it went back down but then gradually went back up by itself....
Old May 20, 2009 | 09:17 AM
93txhonda's Avatar
so ive been pondering this could it be the map sensor ?or the ficv?
Old May 20, 2009 | 09:22 AM
Neither of those sensors would likely produce such a high engine rev. I'd focus more on a throttle cable or throttle body issue.
jodyOs
Feb 10, 2011 05:26 AM
Turbo Tel
Aug 31, 2008 04:45 PM
h22a1hatch
Jan 10, 2008 10:28 AM
coolokydoyk
Apr 30, 2007 07:10 PM
copyguy6188
May 27, 2005 05:08 PM
