High Idle Problem
ok the only thing i didnt under stand was when he said you put two wires in the harness or something??? and move the seat back??? Do you really have to move the seat back? and is it just any old wire you can find that is metal that you would put in there?
Moving the seat back simply gives you more space to work in. A paper clip or any basic wire should work as a jumper for the service connector (located above the ECU and behind the passenger kick panel).
Yes, insert the ends of the jumper wire into each of the two holes of the connector. You want to use the jumper wire to make an electrical connection between the two terminals at the end of the service connector.
rad151
Apr 22, 2009 02:18 PM
liliechen
Dec 25, 2005 11:15 AM
