High warm idle
Old Jun 1, 2008 | 09:43 AM
prionailurus's Avatar
Default High warm idle
I've an issue on my 98 B18 civic. It's idling at 3k, but only once it's warmed up, and I've checked & cleaned the IACV, joined the coolant lines on the IACV & put a plate inbetween it and the IM but left it plugged in to bypass it. I've checked all vac lines, all fine. I've sprayed around the TB-IM and IM-head gaskets, nothing. Basically I've done everything I can think of. I'm open to suggestions, I'm quickly killing my clutch at lights & in traffic.Cheers
Dan.
Old Jun 1, 2008 | 10:04 AM
Default RE: High warm idle
Is the CEL ON?
Check whether the throttle cable is adjusted too tight and whether the throttle plate is stuck open.
Old Jun 1, 2008 | 05:11 PM
No CEL, the cable was fine, but the plate was stuck open slightly, cheers for the suggestion, it's what my dad went for too. There I was with the IACV in bits, again, and messing about with coolant lines & bypasses, and I took the thermostat out too to give me longer before the symptom occurred.
When I got the Skunk2 TB there was a blue compund on the plate and on some of the venturi, I thought this was to help it shut properly, I was wrong, after a little while (the 1000ish miles it's done) the muck had got in and stuck to the blue compound, stopping the plate closing all the way. Cleaned the muck & other stuff off, it still lets a little light through, but nothing I can't live with, and now idles at about 1400, which I'm satisfied about for now, 800 would be better, but this TB is 70mm so it needs a map. If only my OBD2A power FC worked on an OBD1 car I'd be laughing, as is I need to find a UK neptune tuner, and quickly, as I'm probably running lean.
windcalmer
Aug 4, 2013 05:24 PM
SPACEGUY18
Nov 20, 2009 02:01 PM
rockaustin
Aug 24, 2008 06:52 AM
kjreinha
Mar 31, 2006 11:07 AM
Mxsex
Mar 11, 2005 05:35 PM
