high water temp
Old Apr 6, 2007 | 08:19 AM
nahiew's Avatar
Default high water temp
hi guys, i'm new here..
i've got2 problems with my 92 civic SI sohc....
1) the water tem always go upto red zone when the radiator and reserve still has water in it.why is this so?
2) and the radiator seems to have some brown sludge whenever i topup the water.
after some weeks, the reservewater will turn chalky and brown.. and i need to get it replace. previously i got my radiator replaced as the sludge harden and chalked the radiator causing the water temp to went up.
i am afraid history is repeating... so ple advise.. thanks!!!
Old Apr 6, 2007 | 09:01 AM
Default RE: high water temp
are you running ONLY water through it?
Old Apr 8, 2007 | 05:01 AM
nahiew's Avatar
yes you are right.. this is what my technician suggest to me.. he said coolant will "bite" into the component.
so its the water that causes all these??
so pls advise what should i do now?
dismantle the whole radiator and wash it? after that pour in coolant mix with water?
Old Apr 8, 2007 | 06:52 AM
AOL.COM's Avatar
i would change the thermostat & add some 50/50/ coolant mix
Old Apr 16, 2007 | 08:48 PM
BIMMERGUY's Avatar
Add coolant. The specific gravity of glycol is different than straight distilled water. Also, You may have killed your water pump. If the impeller breaks off you will not get any circulation. Does your heat work?
Good Luck
Old Apr 17, 2007 | 03:42 AM
juanortanez031278's Avatar
i think your headgasket needs to be replaced, the way i seethe brownthingyou seeingis water and oil mixture/mixing. that is why your temperature goes that high. while your on it have the cylinderhead shaved just to be sure.
jtyoder
Jan 28, 2008 11:25 AM
hatalowich
Oct 16, 2007 01:53 PM
chrisbyers2005
Sep 3, 2007 08:03 PM
szzy2727
Aug 19, 2007 11:33 AM
Mario89
Feb 24, 2007 07:29 PM
