Honda Civic 1997 LX AC and Oxygen Sensor
here how looks
can you pin point where I can check with the pic?
oh another question poly-rib belt any good?
I got those install for belts..
RonJ, I'm very grateful for taking your time help me out... thank you!
Look for cracks in the exhaust manifold, it's rather common on these models with the one piece manifold / converter assembly (parts 8, 3, and 4). If you idle the engine and stop up the tailpipe with a rag, there should not be hissing of exhaust leaking anywhere. A visual inspection would need to take the heat shield off-- that's the sheet metal part with the number 8 and the arrow on top of it in the picture.
The exhaust system starts at the header (under the aluminum heat shield about where the number 8 is) and below the header is the catalytic converter. Pull off the shield and look for any cracks in the header/cat unit or where the primary or secondary O2 sensors screw in or for a gap between the head and header.
I generally buy OEM timing and drive belts.
Token21
May 20, 2010 10:57 AM
yairsaenz83
Feb 20, 2007 04:04 PM
capn_midnight
Apr 16, 2006 12:07 AM
Traumagas
Sep 28, 2005 11:20 PM
