Honda Civic Dx 1997 Coupe Sluggish problem!
I bought this car used, it has about 148,000 miles. It ran pretty good as far as I knew. I gave it a tune up right away, changed the oil (mobile 1 synthetic), spark plugs and cables, and tranny fluid. I noticed by the oil pan gasket and tranny a small amout of oil leaking, so I went to the mechanic and suggested it was probably the valve cover or the distributor o-ring and also said it looks like I have a blown gasket(how do i know if its blown?it worked fine). I changed both and it still leaked. Then I noticed the fan was not turning on and it was the sensor and themostat, so I changed both. Then everything seemed to be working, but after doing the themostat I noticed a difference in performance, it felt sluggish, I push the gas pedal all the way down in the freeway just to keep up with other cars going about 70mph. I also notice the previous owner welded the catalytic converter.
Any suggestions on what should I do?
Thanks in advance.
Thanks in advance.
slideking
Nov 20, 2010 05:10 PM
Token21
May 20, 2010 10:57 AM
