Horn doesn't work
A couple of months ago, I used my horn for the first time since the wreck. It worked for a second, then died. It used do that little honk when I locked it using the keyless entry. Now it wrong work at all. The under hood fuse is good. Any ideas? I want the thing to work again because I need to be able to inform other drivers that they are idiots.
Just hook up 12v to the horn and see if it works.
Likely this is the horn itself but since you have to take the bumper off to reach it, check some other things first. The horn is on the same fuse as the brake lights, it's under the hood. I don't think it's the button since the alarm doesn't sound it either now.
Strangely enough, I took the car through the car wash for the first time since the wreck and when I got home, I locked it with the keyless remote and it honked! As soon as I start to make a big deal about it, the horn gets off its lazy butt and works.
I traced wires under the hood and it turns out the plug is smashed from the wreck and it was just barely hanging on. When water got on it from the car wash, that was enough for it to be able to make contact. A strip of duct tape later, it's now on there securely (until I get to the junk yard to snag a new plug and maybe a new horn. The higher pitched part is really odd. Makes it sound even more gutless.
"meep meep!"
zeal
12
Jun 18, 2006 11:09 AM
dutchstar
May 9, 2006 01:37 PM
lsuknip
May 24, 2005 02:53 PM
