How To Fix Leak From Engine Coolant Outlet Flange AKA Water Outlet?
Old Sep 1, 2019 | 06:36 PM
lindylex's Avatar
Default How To Fix Leak From Engine Coolant Outlet Flange AKA Water Outlet?
I just did my head gasket and timing belt. I need to know what can I do about a coolant leak from the "engine coolant outlet flange". I think it is also referred to as the "water outlet". This is the part number 19315-p08-010.
I thought it would have a gasket but I do not see one. Not sure how to move forward on this.
Thanks
Old Sep 2, 2019 | 06:31 AM
StifflersMom's Avatar
Cat Fuсker
you can always make your own gasket if you want to out of karropak or the like. I'd guess that there is some corrosion there and the mating surfaces are no longer, well, mating...also could polish the surfaces up on a piece of flat glass with some fine grit sandpaper stuck to it.
Old Sep 2, 2019 | 07:24 AM
lindylex's Avatar
I found this "MAHLE Original C31392 Engine Coolant Outlet Gasket". I wonder if this will seal it. I it would be nice to have some glass but I do not. It feel like to metal surfaces should have a gasket if there is high pressure and temperature liquids traveling by. I have gasket making paper. But that is about as reliable as finding WMD.
Thanks
Old Sep 2, 2019 | 08:46 AM
Cat Fuсker
cork gaskets are pretty reliable.
Old Sep 6, 2019 | 10:44 AM
lindylex's Avatar
[ Solution Solved ]
This gasket did the job "MAHLE Original C31392 Engine Coolant Outlet Gasket".
Turtlegrip
Feb 21, 2020 01:29 PM
annette's honda
Feb 4, 2013 10:10 PM
visago
Dec 10, 2007 11:51 AM
Garon
15
Oct 6, 2007 03:10 PM
DashRendar77us
May 7, 2006 06:33 PM
