How to remove front wheel Hub? - 02 Civic LX
Old Apr 4, 2008 | 08:09 AM
cernicalo1's Avatar
Default How to remove front wheel Hub? - 02 Civic LX
Couldanyone please clarify how the front wheel hub is removed to replace the bearing and the 4 wheel-studs on an Automatic 2002 Civic LX Coupe? It seems that the hub is pressed fit through the Bearings, but this set up does not make sense to me, mainly because I do not see how it is positively kept in place when the entire weight of the car is placed on this area. I have removed the overall assembly which houses the bearing and the hub, and the drive axle does not seem to provide any retention of the wheel hub.
Thank you,
Infante
Old Apr 4, 2008 | 08:20 AM
Default RE: How to remove front wheel Hub? - 02 Civic LX
It's pressed in. Actually the axle does hold it together absolutely when the nut is tight. But with the axle out it still has to be forced apart. Remove the knuckle assembly from the car and put it in a hydraulic press with the apropriate tooling.
Old Apr 4, 2008 | 09:16 AM
cernicalo1's Avatar
Thanks a bunch. I just got it; the exterior end of the drivetrain acts as a retention mechanism once the spindle nut is tightened.
Regards,
Infante
Jeremy102579
Nov 23, 2010 04:52 AM
joey20046
12
Oct 24, 2008 06:08 AM
tuong
Mar 3, 2008 11:32 PM
HARI.
Apr 8, 2007 06:22 PM
phearly
Oct 5, 2005 01:24 PM
