Notching hub to remove studs- pls help
Old Oct 5, 2005 | 02:58 AM
phearly's Avatar
Default Notching hub to remove studs- pls help
Hi,
I read in an earlier post that instead of having to have a machinist press out the wheel bearing, etc... in order to remove a broken/screwed up wheel stud you could "notch the hub" somehow & then put the new stud in. Can anyone explain how this is done & maybe have a couple pictures that might show this?? I've got a '93 EX 2/door. Thanks.
Old Oct 5, 2005 | 08:43 AM
Street Sniper's Avatar
Default RE: Notching hub to remove studs- pls help
Hey, yeah, you just grind down the front so that you can slip the new stud in. You still have to grind the stud down almost flat on one side too. Super cheap solution, as those studs are only like $0.99. I have to change one out this weekend before AutoX. If you can wait until then I can take some pics for you.
Old Oct 5, 2005 | 01:24 PM
phearly's Avatar
That would be great! I can wait to do the replacement. I'll look forward to seeing the pics.Thanks
cernicalo1
Apr 4, 2008 09:16 AM
LarsonSi_0091
Jun 6, 2007 10:22 AM
OCH Orange County Honda
Jul 3, 2006 05:40 PM
Jan 5, 2006 08:38 PM
DZNUTTS
Jun 8, 2005 03:19 PM
