how to replace the clutch
Old Dec 29, 2007 | 10:44 AM
ugh3012's Avatar
Default how to replace the clutch
Is there any DIY that will show me how to replace the clutch?
Old Dec 29, 2007 | 12:06 PM
baker's Avatar
Default RE: how to replace the clutch
buy a haynes manual from your local auto parts store
Old Dec 29, 2007 | 12:39 PM
ugh3012's Avatar
ORIGINAL: baker
Already have one. I like to read from more then one sources before I tackle the job of this magnitude.
Old Dec 29, 2007 | 03:24 PM
Type RB's Avatar
Typically, those technical manuals (like Haynes and Chiltons)are usually source written by the same people - which is why they usually same the same stuff (almost word for word), and share the same illustrations.
Here's an online source for our Hondas. It should (read should) cover your year and model. They're basic instructions in the illustrations, with more detailed sections for each model. http://www.honda-civiconline.com/CIVIC%201995-1997.html
And here's a basic outline of the clutch system from the same people linked to above. http://www.honda-civiconline.com/dat...ed%20Index.pdf
Hope that helps.
Old Dec 29, 2007 | 04:17 PM
ugh3012's Avatar
ORIGINAL: Type RB
Hope that helps.
Thanks....
Old Dec 29, 2007 | 05:34 PM
ya its preaty easy.... hardest part is geting the tranny outta the way
i did mine with the motor.tranny outta the car since it was pulled.... swaping it and slaping it back together is preaty easy... but thiers just one thing you NEED to be carefull with is those guide pins.... mine had two but i messed up one of them and couldnt make it fit back in.. so i just pulled it out and threw it away... ya dont quite need them BUT they do help line the tranny up....
just be sure the tranny goes it evenly before ever doing anything more than finger tight on the bolts..
Old Dec 29, 2007 | 07:29 PM
jasongruter's Avatar
When my clutch went out, I was about due for a t-belt change in my 1998EX.I decided to just pull the motor, change the Timing belt, water pump, Clutch, plugs wires...and about anything else I could change. (within normal reason)Took about10 hours from start to close up.
Nikita
Jul 31, 2014 11:18 PM
LONO100
Oct 11, 2011 01:32 AM
jtvision
Jan 11, 2007 07:58 AM
HARI.
Oct 8, 2006 09:46 PM
Civic Mania 160
Jan 18, 2006 12:49 AM
