hydrolock help
Old Feb 24, 2012 | 08:27 AM
codered24's Avatar
Default hydrolock help
I sucked up water in to my engine and my engine locked up. got the car towed home and got the water out of the cylinders and started the engine there is a ticking sound that gets a little quieter after a few mins. i did a compression test on it last night and got: 1: 115 2: 150 3: 190 4: 205. what do you guy think is wrong do i just need a valve adjustment do i have a bent valve or worse.
Old Feb 24, 2012 | 01:45 PM
#1 is significantly lower than the other 3. There could easily be damage to the engine. You can start with a valve adjustment and see if the tick goes away. You might also try doing a leakdown test to see if the compression improves on that cylinder.
Old Feb 25, 2012 | 08:40 AM
codered24's Avatar
Ya i did a leakdown the compression didnt raise very much it went from 115 to 125.
Old Feb 25, 2012 | 08:43 AM
Make sure the rocker arms go slack when the valves are supposed to be closed. If not, adjust the valves. Possibly it's a bent rod, piston doesn't go all the way up any more, thus low compression.
croninc
Apr 6, 2010 05:13 PM
colby_666
May 7, 2009 05:46 PM
shroomy07CEX
Jun 22, 2008 07:07 PM
ajfd90
Jan 10, 2007 03:40 AM
Jas10hon
Jul 4, 2005 10:35 PM
