I hear noises..... 99 DX
Old Oct 13, 2009 | 01:08 PM
StonedCold's Avatar
Default I hear noises..... 99 DX
When it starts, there is somekind of noise- like a bearing going out. OR something is rubbing on the inside of something. Goes quiet soon after. Runs fine?
After driving, it started having a slight odor. Like a hot wire smell/hot plastic.
Any clues?
Where did RonJ hide the manuals at?
Could this be the A/c clutch going out? OR the Timing belt idler?
Old Oct 13, 2009 | 01:27 PM
Could be a hundred things. Try to localize the noise. Is it engine or is it something attached to the engine?
[edit]
And manuals are at hondatech.info
Old Oct 13, 2009 | 01:41 PM
StonedCold's Avatar
sounds towards the front, center. far as I can tell.
I'm going to change th timing belt if I can find a manual for it.
had it, got it somewhere. can't find it LOL...
Old Oct 13, 2009 | 02:27 PM
Old Oct 13, 2009 | 03:41 PM
StonedCold's Avatar
Thanks!
Old Oct 13, 2009 | 05:55 PM
Noise that occurs right after starting then goes away for good (until the next start) is often the alternator belt squealing. The alternator works hardest right after starting to recharge the battery.
Old Oct 14, 2009 | 06:21 AM
StonedCold's Avatar
Strike one. NOT a belt squeal. It's more like a bearing that needs lube or something. Maybe the a/c Clutch- I"m hoping. But since the car has 168,000 miles. WHO knows if and when the timing belt was changed. SO today it get's a timing belt.
But thanks for the reply.
Old Oct 14, 2009 | 11:36 AM
could be alternator bearing, power steering pump bearing, compressor, timing belt tensioner, water pump
Old Oct 15, 2009 | 07:15 PM
StonedCold's Avatar
a/c Comp clutch died a horrible death........ cut belt off and good to go.......
Old Oct 15, 2009 | 08:32 PM
Come spring time, you can replace just the clutch bearing without replacing the whole compressor or needing to deal with the refrigerant charge.
This is assuming the bearing didn't get so hot that it melted the seal in the front of the compressor, causing a leak.
