IDing an engine noise
Old Nov 7, 2005 | 12:21 PM
bigloaf's Avatar
Default IDing an engine noise
I've got a 1995 Honda Civic DX. Everything is stock. In the past six months the engine has developed a funny noise and I'm stumped by it. When I start the car up after it's been sitting and the engine is particularly cold (like first thing in the morning) it makes a noise that sounds something like psst...psst...psst...psst... As the engine warms up the sound generally goes away. It also tends to either disappear, or just be drowned out by other engine noises as RPMs increase, only to return when the engine drops back to idle. Any ideas?
Old Nov 8, 2005 | 11:13 AM
bigloaf's Avatar
Default RE: IDing an engine noise
Anyone?
Old Nov 8, 2005 | 11:54 AM
are you throwing a CEL or anything?
possible vacuum leak maybe??
Try popping the hood, and letting the car idle. Then stick your head in the engine bay (with caution) and see if you can pinpoint where the sound is coming from. THat will definitely help us try and diagnose the problem.
Old Nov 8, 2005 | 07:12 PM
bigloaf's Avatar
I have no idea what a CEL is. I'll listen for where the soun's coming from though.
Old Nov 8, 2005 | 09:52 PM
mxs's Avatar
mxs
ORIGINAL: bigloaf
check engine light.
Old Nov 10, 2005 | 09:43 AM
potsie's Avatar
You can use a long screw driver or steel rod, put your ear to one end and touch the other end to the part of the engine you think is making the noise. You'll be amazed at how the sound transfers up the srew driver and helps you locate where the noise is coming from.
vdog
Sep 29, 2006 11:35 PM
Bouba87
Nov 7, 2005 09:40 PM
Thorium
Aug 13, 2005 02:10 PM
shisso
Apr 4, 2005 09:15 PM
kerr_iss
Dec 27, 2004 09:48 AM
