Engine Noise in speakers
Old Nov 7, 2005 | 03:12 PM
Bouba87's Avatar
Default Engine Noise in speakers
What is the best way to get rid of the engine noise in the speakers.....it seems to be the RCA cables does it mean that i have to change them?
Old Nov 7, 2005 | 03:15 PM
Remmy's Avatar
Default RE: Engine Noise in speakers
Thats one way. You could use ground loop isolators too. You wouldnt be powering the speakers through and amp would you? If so, check RCA's and Ground wires. Also look for wires that are pinched against metal. Hope that helps.
Old Nov 7, 2005 | 06:59 PM
sacicons's Avatar
chances are, you (or whoever installed it) ran the RCAs too close to the power wire. seperate them and it should get better.
Old Nov 7, 2005 | 08:50 PM
riceburner700's Avatar
get some new spark plug wires, thats why there are insulation over them and that is getting really bad from what you are saying, change the plug wires and you should be good to go
Old Nov 7, 2005 | 09:23 PM
Mark's Avatar
i have the same problem and i heard about the RCAs and power cord. im ruinning an amp to the rear speakers so is it the power cord of the amp or the power cord of the head unit?
Old Nov 7, 2005 | 09:40 PM
sacicons's Avatar
any power cord close to the rcas will make noise.
vdog
Sep 29, 2006 11:35 PM
bigloaf
Nov 10, 2005 09:43 AM
Thorium
Aug 13, 2005 02:10 PM
shisso
Apr 4, 2005 09:15 PM
kerr_iss
Dec 27, 2004 09:48 AM
