Idle Speed Control: Relation to Vacuum System?
Old Aug 9, 2008 | 12:13 PM
turbotiffiny's Avatar
Default Idle Speed Control: Relation to Vacuum System?
I've got a 98 Honda Civic HX Coupe/ Auto 4x4.
When I start the car, it stays at 1.5-2 RPM and then slams into gear when I shift to reverse (which, I have to play w/ the shifter in order to get it to shift bc I think the gears are misaligned) due to the high RPM, I would assume. I will be driving and if my foot is just resting on the gas; not pushing the gas, the gar is bouncing between 1 and 1.5 RPM and does the same thing when I am stopped, idling, in park, etc. Is this a vacuum hose problem? Could it be something as simple as a fuse? I replaced the transmission a year ago and have gone 20k on it, so I am hoping it's not the transmission. The car is maintained well; regularly watch all the fluids etc. It's not overheating either.
Old Aug 9, 2008 | 01:59 PM
Is the CEL ON?
Yes, you might have a vacuum leak (check hoses and connections leading to the IM) or an intake air leak (throttle body or IM). Might also be dirty IACV.
Old Aug 9, 2008 | 02:02 PM
you have a 4x4 civic?
the gear lever cable might be out of adjustment. do a search on the forum about that and you should find info on it.
the rpm issue could be a vacuum leak, or possibly a clogged IACV. go to the DIY section for instructions on how to clean it.
GMC70
Nov 28, 2011 08:31 AM
D16z6
May 29, 2011 05:26 AM
dmsteele92831
Jul 23, 2007 11:10 AM
spcbuck
Aug 26, 2005 11:01 AM
civic9988
Oct 24, 2004 07:22 PM
