I'm on my 3rd ICM... HELP?
Old Aug 27, 2009 | 07:11 PM
shadman52's Avatar
thanks for the replies guys, I popped in my spare PCM and my car seems to be running normal again.
Old Aug 28, 2009 | 10:56 AM
shadman52's Avatar
Well it ran normal for a day and a half, back to my intermitent skip and tach problems again. Its also starting slower now, think Im gonna pick up a used distributor asap.
Old Aug 28, 2009 | 11:57 AM
Buy a new Honda distributor for the long run. Check price at Majestic Honda.
Old Aug 28, 2009 | 12:01 PM
...I popped in my spare PCM and my car seems to be running normal again.
I was skeptical that the ECU would be the solution because the ECU only provides ground for the ICM to tell it when to signal the coil to fire.
Old Aug 28, 2009 | 07:23 PM
shadman52's Avatar
Well I bought a distributor from a local junkyard today, installed it on my car, drove around for awhile, it ran good for awhile. I drove to my parents parked it for a couple hours, drove back home and no less than 10 minutes into the drive, it starts skipping again, feels the same as before, only this time my tach stays at a steady rpm while the engines skipping. Any other suggestions guys?
Old Aug 29, 2009 | 05:41 AM
Tach staying steady means it's likely a different problem now. The ICM is probably firing OK but the spark doesn't make it to the plugs (hint: ebay wires). Or it could even be a fuel problem.
But no codes?
Old Aug 29, 2009 | 12:14 PM
shadman52's Avatar
My wires are 8mm silicone Accels, they are very high quality and were not cheap, they are clean and in good condition. I cleaned the inside of the cap and rotor today, it was slightly dirty, reset my PCM, but nothing has helped yet, it still skips intermitentlly, sometimes the tach still drops when it happens as well. When the check engine light comes on again i'll pull codes again, but last time it was misfires cylinders 1, 2 ,3 ,4 and "multiple misfires"
Old Sep 26, 2009 | 12:08 PM
beavisj's Avatar
MSD coil, distr., & wires are good & they are on ebay
drumforever
15
Jun 8, 2009 03:50 PM
crazyflippindude
Oct 29, 2008 09:28 AM
GAMBOA
14
Nov 23, 2007 01:59 PM
honda_farmboy
20
Aug 7, 2007 05:29 PM
billthepill
Jul 14, 2005 01:49 PM
