Improper ignition timing
Old Apr 4, 2010 | 03:40 AM
sparxd-series's Avatar
Question Improper ignition timing
Ive got a d16z6 block w/ d15b7 head spinning a d16a6 camshaft but having trouble w/ ignition timing when using timing gun. Timing marks on crank pulley is off about 2inchs from timing pointer.
Top and bottom both set properly but just having trouble getting accurate timing when pointer doesnt come within range of marks on crank pulley. Has anyone ever corrected this sort of issue? An output would be really appreciated.....
Old Apr 4, 2010 | 05:03 AM
You have to put the test jumper on (like you would to read CEL codes) to set the ECU into test mode before setting the timing. The ECU will advance the timing by a large and variable amount off of the marks in normal run mode (no jumper).
Also make sure you have a key in the crank pulley slot, so the single TDC mark is really TDC.
Old Apr 4, 2010 | 11:38 PM
everything is pretty much notched up and also used jumpwire.could it be that im running an d16a6 cam along w/ a d15b7 head and using stock a6 cam gear and that its a degree off?
Old Apr 5, 2010 | 06:08 AM
The mechanical timing may be off by 1 tooth of the timing belt.
Mecca8383
Jul 7, 2010 05:52 PM
gas_miser
Sep 18, 2008 07:23 PM
top99sir
Mar 4, 2006 01:24 PM
hondadelsoldrvr
Mar 3, 2006 05:18 PM
mxs
Routine Maintenance DIYs
Jan 30, 2006 07:16 PM
