Installing Air Conditioning
I'm lookin' to put an AirCon system into my '96 CX (base model) and was wondering if it would be a direct drop-in from another honda AirCon unit? I have an HX that has A/C that I can swap in, if so. Has anyone here done it and what do you think the "skill rating" would be on this? Cuz OMG, I can live with no Power Steering and no Power Windows, but D*MN, I can't handle no A/C!!! Thanks!
Any idea where I might find some kind of guide, DIY, or any info whatsoever to take it out? Or did you just take out anything hooked to the A/C itself? My Haynes manual WILL NOT show it because it "venting refrigerant to the atmosphere is dangerous/illegal and should only be accomplished by a qualified professional".
Yeah, I forgot about that part.. It's really straight forward except for releasing the refridgerant or whatever. And you do not want to be anywhere near it when you do pop it. What we did was loosen up the release, tied a string to it, and pulled the string from about 10 feet away. It will shoot everywhere! BEFORE releasing, make sure you have secured everything. By that I mean tie all the hoses to something sturdy so that they don't flail all over the place. Also do all of this outside, we did it in my garage and it stunk for an hour....not to mention the taste [:'(]
recap
1 - Tie all hoses to something sturdy so they don't flail
2 - Tie a string to the release point
3 - Loosen nut on release point
4 - stand a good distance away and pull the string to release refridgerant
5 - then remove the rest from there.
recap
well when you start , you dont have all that pressure.
think i saw harbor (china) freight with a unit that was cheap to take the pressure down below atmospheric pressure.
think the pressure is taken down to zero before filling.
good luck
good luck
ORIGINAL: fglaustin
good luck
good luck
Before you recharge the A/C you will want to put the A/C under a vacuum to get all the water and contaminants out of the system. After you put it under a vacuum you can recharge the A/C. You can use the cans that you buy at autozone. You would prolly only need one can of refrigerant and one can of oil. Even better would be to find the can with both.
