Jerkiness while accelerating (98 Civic HX)
Old Feb 14, 2006 | 10:39 AM
elysian's Avatar
Default Jerkiness while accelerating (98 Civic HX)
Hi, I'm new to the forum. I just bought a used 98 Civic HX MT with about 100k miles on it. I've noticed that when I'm accelerating in 3rd or 4th gear, it's not smooth but kind of jerky. It's kind of hard to describe and doesn't happen all the time. It usually happens when I'm accelerating on a long stretch of road in 3rd or 4th gear. I guess you could describe it kind of as having your foot on the gas pedal, applying pressure, releasing, applying pressure, releasing, etc. I got the timing belt changed the second or third day I bought it. I've also recently changed the spark plugs. Any guess as to why this happens? Could it be the ignition wires need to be changed?
Thanks in advance for any info you can give.
Old Feb 14, 2006 | 04:56 PM
polo708's Avatar
Default RE: Jerkiness while accelerating (98 Civic HX)
the plug wires are a possibility, but it sounds like fuel starvation (you are running lean)... dirty/clogged injectors or a bad fuel pump are some possibilities. Hard to really say over a computer.
Old Feb 14, 2006 | 05:21 PM
dj_ipirate's Avatar
dump some seafoam in there and see what happens. you really dont want to burn lean...
Old Feb 15, 2006 | 09:07 AM
AgentofDarkness's Avatar
You could prolly use a tune up, it can't hurt. You already changed the plugs, so it might not be a bad idea to change the plug wires, fuel filter, and air filter. If you are running lean, the computer should compensate for this by making the A/F mixture rich. You could check the O2 sensor with a scan tool. So when your car is hesitating, you can see what all the sensors are doing.
Old Feb 15, 2006 | 07:48 PM
97 Black Civic's Avatar
Change your air filter.
Old Feb 15, 2006 | 08:09 PM
riceburner700's Avatar
also might want to check the motor mounts
92utownxj
Jun 30, 2015 07:10 AM
apexnine
Apr 12, 2011 07:05 AM
megafandrew
May 12, 2009 08:11 PM
hatchback virgin
Jan 4, 2009 04:00 PM
Falhawk
Jul 14, 2005 03:12 PM
