Just got a coupe! Love it but I have a ?tranny problem
Hi all! Just purchased a 99 Hx coupe in silver. Has 98K miles on it with an auto tranny. I love the car, seems solid and would last me for a long time. The only problem is when I step on the gas from a stop or when the car is rolling and I push the car a bit. The whole car shudders and hesitates. Then after 2 seconds the car accelerates without problems. If it was a manual transmission I would describe it more as a clutch slipping. Can it be a torque converter issue or possibly drive shaft? The engine seems fine and smooth, probably just needs a tune up. I can shift thru all the gears in the auto tranny smoothly also. Thanks all in advance for any advice.
Hey i got this same problem with my 97 Coupe EX, just got it like 4 days ago, auto tranny too, from what i read i think i might have to check the torque conv too just in case, i feel that its not letting those horses out as it should for a VTEC engine when i floor the pedal, the motorseems to be in goodshape itonly has 96k miles on it as per the marker says, ill try to change all the oils and see if any difference, also would 17" rims affect the torqueor acceleration of my car?, i bought the car with those on ive heard they might affect it. When i do the changes ill post again and see if any results and hopefully some pics too.
Thxin advance.
Thxin advance.
Well, just changed engine oil, spark plugs, air filter which were EXTREMELY dirty and the shuddering got a lot better but still has a bit left. The next day I got the CVT fluid from the dealer and drained and filled the transmission. But that didn't change much of anything. Is there something with the engine that can possibly be the problem? since changing the eingine oil, plugs and air filter helped so much? While changing the tranny fluid didn't make much of a difference?
HuGGyBear305
Mar 9, 2008 11:33 AM
jrobida999
Jun 26, 2006 05:59 PM
Talon585
Mar 21, 2006 12:46 AM
2000 LoW reD Si
Nov 11, 2005 01:06 AM
