Knocking Sound
Old Jun 18, 2015 | 11:46 AM
Funnyman's Avatar
Default Knocking Sound
So this weird knocking sound started in my car about a week ago. I know it's not coming from the engine. I think it is coming from the wheel or axel, but I don't see anything when I look down there.
I think it is from the wheel because the sound increases when I go faster. When I brake, turn, or accelerate the noise goes away. It comes back when I let the car coast or put it in neutral.
I have no idea why this started the only thing I can think of is that my brother curbed my car, but that was like a month ago. But maybe it bent something?
Thanks, I will post a video of it when I get a chance.
Old Jun 18, 2015 | 06:29 PM
itburnswhenIP's Avatar
i could be something as simple as the wheel weight fell off or it sounds like it is most likely a bad wheel bearing. you can check the bearing by jacking the car up onto jack stands and grabbing the top and bottom of the wheel and rocking it back and forth if there is any vertical movement its a bad bearing. other things to check would be lug nuts,lower control arm bushings and ball joints.
willfred
Nov 8, 2008 09:49 AM
ccselvido
Aug 22, 2008 06:10 AM
ccselvido
Aug 18, 2008 12:21 PM
atthe123
Jun 6, 2008 10:49 AM
thebeast
14
Oct 28, 2005 01:15 PM
