license plate light / trunk lights
Old Sep 23, 2010 | 04:57 PM
wireyanker's Avatar
Smile license plate light / trunk lights
05 civic lx has all tail lights working except the trunk only has brake light and back up. the other 4 do not work. checked for corroded ground on lip of trunk. fuses if under the hood etc. Is there a 2nd fuse panel? Or is there a common problem I don't know about? replaced all lamps of course already. thanks
Old Sep 23, 2010 | 05:29 PM
i do not understand you.
if all your taillights are working then what is wrong? your license plate do not light up? how many lights do you have back there?
Old Sep 24, 2010 | 08:02 AM
Broken wires between the body of the car and the trunk lid. Wires may look OK on the outside but the copper inside breaks.
Old Sep 24, 2010 | 12:27 PM
wireyanker's Avatar
I'll check that as this trunk is used often.
Old Sep 25, 2010 | 01:47 PM
wireyanker's Avatar
OK, so if you look at the part of the harness that moves with the trunk opening there was indeed a splice crimp that broke off. It was just slightly up from the main branch of wires that go towards the rear and up and right about 2 feet from the large plug behind the seat. All fixed.
itzcorky
Nov 13, 2013 06:26 PM
itzcorky
Sep 21, 2011 07:45 AM
93ċiviכֿ
Dec 6, 2008 10:32 PM
colby_666
Jun 11, 2008 07:02 PM
DXhatch
May 31, 2007 05:02 PM
