Lights are effed up
Old Apr 15, 2012 | 12:25 PM
solohan's Avatar
Default Lights are effed up
ive been working on my lights forever and i havent been able to make them work right, its always something, but the main problem is that whenever i break my front signal lights come on, and my upper brake light stays lit when the lights are on, also whenever i break the wind shield wiper wipes.
im not sure all the infomation you'd need to maybe help me out but ask and i can tell you
97 honda civic EX
Old Apr 15, 2012 | 01:42 PM
Not sure about the last one but the first 2 are caused by bad grounds. You need to make sure the shells of all the dual purpose bulbs in the trunk are grounded. Otherwise there will be crosstalk between the brake lights and the running lights.
Turn lights OFF and put a weight on the brake pedal so the brake lights stay on. Now look at the back of the car. The brake lights that light up dimly are not grounded. The ones that come on bright are probably OK.
This will also happen if the wrong bulbs are used. Putting an X156 (round bulb with single contact) in a X157 socket (two contacts on the bottom of the base) will bridge the two circuits.
itzcorky
Sep 21, 2011 07:45 AM
kfreddy2o2
Jun 6, 2011 08:40 PM
Sleepin95CivicDX
Oct 6, 2006 11:26 PM
93hbSIgsr
Mar 18, 2006 06:13 PM
xe1002
Jul 10, 2005 12:45 PM
