Linear Solenoid help!
Old Oct 5, 2011 | 07:07 AM
Borderman's Avatar
Default Linear Solenoid help!
Hi everyone. I am new to this forum. I don't have a lot of mechanical ability but hey, I'm trying! I have a 1997 Honda Civic LX 4-door w/auto transmission. I need to replace the linear solenoid P/N 28250-P4R-315.
I have the part and transmission fluid but I'm not sure where the linear solenoid is. Do I access it from under the hood or under the car? Is it hard to replace? Can someone post a picture of a similar Civic showing where the linear solenoid is? Any instructions on how to replace it would be GREATLY appreciated. Thanks!
Old Oct 5, 2011 | 07:35 AM
It's on the outside of the transmission, on the front, toward the end that is away from the engine. Reach it from under the car (take the splash shield off first). Once you have the new one in your hand it should be obvious where it goes.
Old Oct 5, 2011 | 07:45 AM
Borderman's Avatar
ok so it faces toward the front of the car or faces toward the passenger side?
Old Oct 5, 2011 | 07:54 AM
Faces the front of the car. I don't know much about automatics I'm just going by this diagram:
Honda Automotive Parts
The linear solenoid is part #32. Also of course you would use a new gasket #33.
Old Oct 26, 2011 | 07:58 PM
ttd's Avatar
ttd
Default Transmission fluid refill
A mechanic told me to also replace my 1998 honda civic linear solenoid because I was having harsh shifting. But before that, he told me to flush the tranny fluid couple times to see if it would make a difference.
How much fluid am I suppose to put back into the tranny? 2.9Q according to spec? or the amount drained out of the tranny when I first drained it, which was about 2.5Q? yes, i used a measurement cup to be sure the mechanic said i should put back the same amount that I drained out initially. does that sound right?
Old Oct 27, 2011 | 10:44 AM
zerojett's Avatar
i have always filled it until fluid starts coming out the fill hole.
also, get some Honda Manual Transmission Fluid from the Honda dealership. It isn't too pricey, and it really makes for a smooth transmission. You'll need 2 bottles.
Old Oct 27, 2011 | 01:17 PM
He has an AT, why do you suggest MTF for him?
OP, I wish I could help, but I don't have any experience with AT's. All I know is that they have a transmission cooler embedded within the radiator which hard lines to go and from. Sorry I couldn't be of more help.
Old Oct 28, 2011 | 06:08 AM
ttd's Avatar
ttd
I went to the honda dealer to pickup some AT fluid. The guy told me to just fill it thru the dipstick area until it reach the top mark of the dipstick. Now I just need to find somewhere that sells the linear solenoid cheaper than the dealer.
Thanks for all your help guys
MaximusFunk
Jan 3, 2011 11:29 AM
laddylam
Apr 25, 2008 03:45 AM
greycoupe
Jan 17, 2008 01:36 PM
Methu969
Nov 5, 2007 07:28 PM
Methu969
Oct 30, 2007 05:23 PM
