Loud grinding
I have a 91 civic dx and as of latley I have been getting this grinding noise from my front right brake area. It doesn't do I all the time and when I completely stop the grinding will stop only for a while, then it will start back up again. Does anyone have any ideas?
could be many things.
on my dx, it was the dust shield grinding against the disk.
a grinding noise could be the sound of a bad wheel bearing also.
best thing to do is to pull your wheel off, unbolt the caliper, inspect the pads and both sides of the brake disk. You'll need a jack, wheel wrench, 17mm or 14mm (Can't remember) socket + extension, 12mm socket, and possibly a large phillips head screw driver to take the retaining screws out of the disk. My passenger brake disk has a nice half inch wide groove cut into it from that dust shield... =(
red_sleeper
Feb 12, 2005 11:49 PM
