low IDLE
Old Jul 2, 2007 | 01:27 PM
Fragranttuna's Avatar
Default low IDLE
Now i konw alot of people have idle problems but they never seem to help reading there replys...so here it goes...
When i turn the car on it idles fine and dandy. But when i start driving for a while (5 min or so) and i stop at a light or stop in general and just leave it in Drive, the rpm's seem to drop alot,like hover around 200-300rpms, this only happens when i let off the gas, or idle...any thing?
Old Apr 22, 2008 | 06:50 PM
BLaCkSiLo's Avatar
Default RE: low IDLE
bump.... i have the same issue... hovers around 500 rpm, and shakes a little bit
Old Apr 22, 2008 | 06:59 PM
ORIGINAL: BLaCkSiLo
Is the CEL ON?
1) Clean the IACV and also the Fast Idle Valve, if you have one.
2) Adjust the idle screw on the throttle body.
Old Apr 22, 2008 | 07:06 PM
croninc's Avatar
my car today was idling at 1.5rpm this morning and throughout the day when I had the clutch in all the way, having this same problem, someone told me it could be the thermostat
Old Apr 23, 2008 | 12:55 AM
grove's Avatar
i have the same problem. and i have already cleaned the iac valve. and i dont have a fast idle valve to clean. ive checked both of my sensors to see if that what the problem and they both work fine. so now im still confused on what it might be.
Old Apr 23, 2008 | 03:47 PM
BLaCkSiLo's Avatar
Is the CEL ON?
no, the CEL is not on, it's kind of a wierd deal, i just noticed today that if i'm cruising along at say 30mph, push in the clutch and coast, the car will idle normally around 8-900 rpm, but when i get to a complete and full stop, then it drops the idle to around 500 or so rpm's
this is confusing to me because technically the clutch disengages the engine from the wheels so no matter what the wheels are doing the engine should idle the same?
i will work on cleaning that valve, but i'm pretty sure the thermostat is okay because it heats up, blows hot air and cools down accordinly with the guage working fine
i'm kind of lost on this one, if anyone has figured this thing out, please post
thanks for the help
JBaris
Nov 22, 2010 03:56 PM
sebdiz
Apr 28, 2010 05:45 PM
boostphreak
Aug 27, 2008 11:15 AM
liliechen
Dec 25, 2005 11:15 AM
icarus
Nov 21, 2005 08:32 PM
