Low Idle with code
Old Oct 8, 2011 | 11:46 AM
nobily's Avatar
Default Low Idle with code
I have a 1998 honda civic ex auto trans. 130k miles. When push on the gas peddle the rpms go up very slowly. It only goes to 3k rpms then surges back down to almost 0 rpms. When I put it into drive it drives but very slowly and I have to push the gas peddle to the floor board. In reverse I have to use my foot like Fred Flintstone and give it a little help. My check engine light is on with P505. I have checked for vacuum leaks (none). I checked for air inside coolant (none). I did replace the PCV valve. I put my finger over the lower port inside the throttle body, the car dies. I have checked for leaks on my manifold gasket (none). I have taken off my iac valve and cleaned it. I verified the TPS with a volt meter (it was good).
Before I spend $200.00 for a new IACV, is there anything else it could be??
Old Oct 8, 2011 | 12:46 PM
It's not the IACV. That only affects idling. You have a more major problem since it won't drive properly either. If the tach reads zero while the engine is turning, the ECU may not be getting proper pulses from the distributor.
Old Oct 9, 2011 | 05:40 PM
techlight's Avatar
I had a similar issue with my 00 ex. It felt like I was driving under water. You might try checking your MAP sensor. This partially fixed my problem, however I also had timing issues that needed to be fixed (cam timing was out as well). If you have a scanner you check what the MAP is reading and see if it's within spec in accordance with the service manual...(or spend 60-100 bucks to buy one haha.)
Good luck.
Hope you get it fixed.
Old Oct 10, 2011 | 05:51 AM
nobily's Avatar
This has become very frustrating. I'm getting a code with my check engine light P0505. Yet the problem might not be anything to do with the IACV. I think it might be best to get it towed to a shop with better scan tools.
Old Oct 10, 2011 | 09:10 AM
mpklkj's Avatar
take your negitive cable off for 5 mintues hook it back up and start the car it will clear your check engine light it prob will come back on see if it makes a diffrence
Old Oct 10, 2011 | 03:56 PM
nobily's Avatar
I've done that, it still comes back with the same code and issues.
Old Oct 18, 2011 | 12:28 AM
nobily's Avatar
It's fixed now!! New timing belt, new spark plus, new fuel filter and new water pump. $360.00 later and my civic is alive again!!
nobily
Oct 8, 2011 07:08 AM
JBaris
Nov 22, 2010 03:56 PM
sebdiz
Apr 28, 2010 05:45 PM
boostphreak
Aug 27, 2008 11:15 AM
lowranchero
24
Feb 18, 2008 02:56 PM
