Low Idle and IACV
My 96 Civic (D16Y7) has a very low idle at times so I did a search here and found that cleaning the IACV sould proably solve the problem.
According tomultiple references,the IACV is located at the rear of the throttle body on the D16Y7 motor but I don't see it there on mine.
I have what looks like the IACV located at the front of the throttle body. It has 2 heater hoses attached to it, an electrical connecter and is mounted to the throttle body by what looks like four 10mm nuts. Can this be the IACV?
You are correct. The IACV on the D16Y7 is located forward of the throttle body and behind and below the fuel rail. Based on your description, you have correctly located the sensor.
ORIGINAL: Perry
It looks like the IACV can be removed without taking off the fuel rail by removing the heater hoses and electrical connection first. Is this true?
Juice75
Dec 15, 2012 05:16 AM
jlor010
Aug 8, 2010 06:21 AM
faifu27
May 29, 2010 05:19 PM
jamisonh
Feb 21, 2009 10:17 AM
boostphreak
Aug 27, 2008 11:15 AM
