maintenance required light
Old Feb 13, 2005 | 08:49 PM
payam's Avatar
Default maintenance required light
yo
when i start my car, the maintenance required light will flash three or four times and then shut off. is that normal or does it need maintenance?
Old Feb 13, 2005 | 10:06 PM
Remmy's Avatar
Default RE: maintenance required light
the only time mine blinked like that was when I went thru a 3 foot deep puddle at 30 mph. My engine started stalling but the water that was sucked into my ram finally dissapated and the engine was fine.
Old Feb 14, 2005 | 11:01 AM
payam's Avatar
tech at honda said it's normal up until my 10k mile tune-up. not sure if that makes sense, does it?
peace
Old Feb 14, 2005 | 01:17 PM
red91civicDX's Avatar
BS. If the light came on it set a code. It's either current or in history. Make them scan it. Ask them for the code.
Old Feb 14, 2005 | 03:50 PM
Remmy's Avatar
ive got 65,000 on mine... might need to do it. Is it easy to replace? And if so where is it on a 99-00 civ?
whoops, wrong thread... i was talking about my rear O2 sensor.
Old Feb 14, 2005 | 06:51 PM
sacicons's Avatar
no, its the maintenence required light, not the check engine light. id go with what the tech said. if it was the CEL, then you could pull the code, but if its MR, then just trust the tech.
Old Feb 14, 2005 | 09:08 PM
Remmy's Avatar
well, i figured that might have something to do with it since he manual said the check engine light normally refers to emmissions
Old Feb 14, 2005 | 09:51 PM
sacicons's Avatar
i meant in response to red91. just wanted to clear that up.
Old Dec 6, 2005 | 10:55 AM
maximummax001's Avatar
That's a big help... I wasn't sure if something was wrong or if it was just since I changed the oil. So let me get this straight: a "check engine" light means that the computer threw out a code and the "maintenance required" thing that it not a light (in a 98 anyway) means that a certain interval has passed or it means you changed the oil. Right?
civic4ever
Apr 3, 2007 04:36 PM
speedstream
Dec 8, 2005 04:19 PM
Copperhead
Aug 28, 2005 08:52 AM
ImportFreek
Jun 3, 2005 07:13 PM
ImportTrendz
Sep 7, 2004 05:13 AM
