MAP Sensor?
Old Aug 6, 2011 | 06:56 AM
Pagan's Avatar
Default MAP Sensor?
So I went to go read why my car was showing a check engine light and it said that my sensors were bad... both are brand new. So I spoke with a friend of mine that works with civics and he said that it might be the MAP sensor. Is there a way I can clean the map sensor? If not, what else do u guys think it might be?
Old Aug 6, 2011 | 09:06 AM
What specific codes did it throw? If it threw both the MAP and TPS, you might have the plugs switched around. (They're the same plug type.)
There is a MAP sensor cleaner spray. You'd find it next to the carb and brake cleaner.
Old Aug 7, 2011 | 08:58 PM
Pagan's Avatar
Iight thanks man, just finished cleaning the map along with the chamber where the oil gas and air hits. Hopefully it gets better after 50 miles or so lol
Old Aug 9, 2011 | 03:49 PM
Pagan's Avatar
dammit... the check engine light is still on... and now my car keeps jerking when im cruising... what would be the meaning of this...?
Old Aug 9, 2011 | 05:18 PM
Pull the code.
00sithrottle
May 12, 2005 10:25 AM
firzout
Apr 8, 2005 11:22 AM
scooterspeed
Mar 12, 2005 07:28 PM
red_sleeper
Jan 15, 2005 01:08 AM
