Missing oil
Old Mar 14, 2005 | 07:18 PM
StifflersMom's Avatar
Cat Fuсker
Default Missing oil
Well I was minding my own business, driving from school, when the oil light comes on right when I stop at a red light. It went away the moment I stopped decelerating, so I thought that its not a big deal and I could just go home(2 more miles). Well the same thing repeated on three next red lights. I got home and checked the oil...there "appeared" to be a minimal acceptable amount in there. I was going to do an oil change anyway so I proceeded with that...to my great surprise all that drained back was about a quart...I filled if with fresh oil, put the new filter on, and wiped the spills off. I turned the engine on and let it idle for a few minutes, than I reved it for a few minutes, no visible leaks, so I waited 15 minutes and pulled the spark plugs, clean as new...there's a sludge buildup on the oilpan, so I suspect a gasket leaking there, but it doesn't drip. I always check under my car. Any thoughts on that?
Old Mar 14, 2005 | 11:36 PM
sacicons's Avatar
Default RE: Missing oil
how is it now? is it getting low again? do a compression test, you may have a bit of blow-by in the rings.
Old Mar 15, 2005 | 12:03 AM
Cat Fuсker
I haven't had a chance to drive it for more than 10 minutes since the oil change...I'll do a compression test tomorrow, but damn....couldn't have been worse timing for a major problem...
Old Mar 15, 2005 | 02:22 PM
Cat Fuсker
Drove it for 10 miles, again oil light comes up, there's almost no damn oil anywhere, no leaks can be found and no oil on the spark plugs...couldn't do a compression test today, but this doesn't seem right at all
Old Mar 15, 2005 | 02:30 PM
blackeyes's Avatar
r u smoking from ur muffler?
Old Mar 15, 2005 | 02:34 PM
Cat Fuсker
No smoke at all...and the engine is as smooth as ever...
RunNRhino
Aug 15, 2012 07:05 PM
stan24
Nov 28, 2011 01:05 PM
oilltd
Jun 10, 2008 04:06 PM
gr8_2_av8
Dec 7, 2004 05:20 PM
