motor swap 90 honda civic D16Y7
Old Sep 9, 2009 | 02:57 PM
biga's Avatar
Question motor swap 90 honda civic D16Y7
k my previous question was helpful,however,the motor that i have access to is in fact a D16Y7 not the d16a6 like i thought so with that being said,is it still a painless hookup other than wiring for the injectors,also can get the ecu and whatever else i need from car.so will it work without changing mounts or pulling all the wiring out please help,getting whole car pretty cheap.the motor and trans is in a 91 honda crx now.
Old Sep 9, 2009 | 03:28 PM
well if its in a 91 crx already it will fit perfect. the ecu should be a pm6 out of the crx. you will also need a resistor box and just wire the 4 fuel injectors and the 2 wires from the distributor( just like the diagram i posted for you.)
Old Sep 9, 2009 | 03:31 PM
biga's Avatar
so i started the car and it ran fine,will i need a resistor box or will there be one on the crx somewhere?
Old Sep 9, 2009 | 03:39 PM
there will be one one the crx its a grey box under the hood where the wire harness tower is on the driver side.
post pics of the engine and i can better help u
Old Sep 9, 2009 | 03:42 PM
biga's Avatar
thanks i will look in that location if cant find i will post pics thank you again.
Aaron A Archer
Dec 3, 2011 03:38 PM
toughtransam36
Sep 28, 2010 05:40 PM
droopy128
Drivetrain DIYs
Feb 18, 2008 05:15 PM
vborelli98
Aug 21, 2006 05:30 AM
headache96civic
Jun 3, 2006 01:45 PM
